Transmission Damper plate on 8.1 L w/ Hurth
Does anyone have experience changing a transmission dampener plate on a Hurth transmission w/ 8.1 mercruisers ?
Before you blame the damper plate and change it, make sure the engine idles perfectly smooth. I just had lots of clanking sounds in my starboard Hurth transmission. Hurths are know to rattle if everything is not perfect. After putting in new plugs to correct rough running the xmission noise went away and the engine ran like new. I took out the Denso plugs and installed #41-993 AC Delco's at about 300 hours. Capt. George
  [Tiara Coronet] ZF Transmission Noise Ceili 4 1,705 10-05-2025, 07:55 PM
  Differences in Port and Starboard ZF Transmission pressures and temperatures rmsullivan1@gmail.com 3 3,195 12-19-2024, 08:43 AM
Last Post: rmsullivan1@gmail.com
  [Tiara Open] change tran fluid and filter on hurth waycamp 4 4,056 09-13-2023, 10:19 PM
Last Post: Joeboch348
  [Tiara Open] 2006 Tiara 42 Open Transmission Kphillips 1 2,152 07-12-2022, 09:00 PM
  [Tiara Open] replace oil/transmission cooler waycamp 4 4,503 01-05-2022, 05:04 PM
