3100 Water Tank Replacement
Hello- I have a 1993 Tiara 31. Unfortunately the poly water tank is leaking due to a long fracture along the top edge (on the hull side), so repair is out of the question. It looks like the tank will have to be replaced . I hopefully can do it without removing the starboard engine (Crusader 454's). It looks like it may be doable if I remove the manifold, riser and exhaust hose and drop the heat exchanger and oil cooler. Has anybody done this?
Thank you, Keith
  89 3100 convertable kps@dundee.net 1 1,128 10-30-2026, 06:13 PM
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 987 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,391 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,599 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,387 09-17-2025, 05:52 AM
Last Post: Splendor
