Threads: 8
0
02-15-2016, 07:29 PM
(This post was last modified: 02-16-2016, 08:59 PM by mikefromlb.)
Original stove top on my 1989 Tiara 33 Open stopped working. Microwave is working fine.
Stove and Microwave seem to be a combo unit.
Do not have Tech. Manual to troubleshoot.
Can knowledgeable owners share your thoughts how I can get it working again.
Thank you.
Threads: 22
5
Home Port: Stuart, FL
On my '88 36, the stove and microwave are on two seperate 120 volt 20 amp breakers. They are not a combo unit. The red power indicator only comes on after a burner is turned on. As I recall, my 31 was the same way. Hope this helps. Capt. George
Threads: 22
5
As a follow up when I was on my boat, the wire size is #12 AWG and the connection is hardwired in a junction box under the right rear of the stove. The stove is held in with two screws on each side that are screwed into the counter top. I would lift it out and measure the voltage for starters. Capt. George
Threads: 22
5
02-21-2016, 08:31 AM
(This post was last modified: 02-21-2016, 08:44 AM by Uhehner.)
You should be looking for a circuit breaker panel where the main AC meter is displayed. Not a fuse panel. And I would not expect it to be in the cockpit area but rather in the cabin. The stove will not be on a fuse. Looking at pictures of a 33 Open power panel, the stove breaker is the second one from the top of the AC section. Capt. George
