2006 36' Open Cockpit Fridg.
I recently purchased a 36' 2006 open it has a fridg. in cabin and one in the cockpit behind helm.
Both units are A/C D/C but the only the unit in cabin works on D/C. There is a circuit breaker switch , under steps, for both units on a/c panel but only one switch in the D/C panel.
I can't get a straight answer from Tiara if they wired vessel to run both units under D/C power or just the cabin fridg.
Anyone out there with similar boat. Thanks Frank
Sundance marina in Pompano did some work on my 40 , not fuel related but if they don't do it they will know who will .
I am in NY, looking for some one with a 36' Tiara with two refrigerators. Thanks
Frank,
I can tell you with 98% certainty, you will not find any pre wired harnesses for deck fridge. In 2003/2004 we began pre-wiring options but only the wires for "long wire run" options were put in the standard harnesses. If the option had one or multiple separate option specific harnesses they were not manufactured. I can also tell you when an option was not installed any wiring for that option was wire tied back as far as possible and hidden. This way technicians would not confuse the wiring with other component circuits. I have seen technicians waste many hours trying to locate hidden and non-existent wiring. You will be ahead in the long run to install new wiring.
Brian Kane
Customer Service Rep.
Tiara, Zeelander
725 E 40th St
Holland, MI 49423
Phone 616-394-7163
Thank you
No pre wire harnass so ran a new wire all is good.
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 4,534 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 5,211 03-04-2026, 05:56 AM
Last Post: ken9090z
  [Tiara Open] 1996 33 open gauges Mydiamond 1 5,586 08-18-2025, 10:57 AM
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 5,220 08-14-2025, 08:05 PM
  2006 3600 Sovran Final Pursuit 3 5,856 08-09-2025, 02:35 PM
