Tiara Open 1996 33 open gauges
What is everyone using to replace the old VDO gauges.
I like the rear twist lock system and flush mount.
Looking for suggestions
Thank you
I have been using new VDOs but it is a pain. The new ones are a typical gauge mount so they are installed through the helm, not from behind. They are also a little larger diameter so I need to use a dremel to increase the size of the opening. Have to also remove a large plate behind the helm to mount from the backside. Eventually I am going to redo the entire helm and eliminate that big aluminum plate, probably over the long WI Winter.
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 4,531 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 5,208 03-04-2026, 05:56 AM
Last Post: ken9090z
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 5,218 08-14-2025, 08:05 PM
  [Tiara Open] 1995 Tiara 2900 Gauges cd1154 5 4,418 08-05-2024, 02:27 PM
Last Post: carbon20
  Gauges for Tiara 2700 stanfarbman 2 3,539 09-12-2023, 08:25 PM
Last Post: stanfarbman
