08-04-2016, 02:53 PM
I'm the second owner of a 2009 Sovran purchased in 2014 in Boston and relocated to Branford CT. During the survey a leak was discovered in the port engine (Volvo D600) hydraulic pump which circulates fluid to the IPS drive. Engine hours were approximately 250 at time of purchase. Mcdonald Marine a highly respected CT licensed Volvo service firm replaced the pump under warranty (I had to pay to haul and replace the the hydraulic fluid) during July 2014. A year later the same pump failed again and was replace by Mcdonald in June 2015 under warranty. This past weekend I found hydraulic fluid in the IPS and the underside of the year old port pump was wet to the touch. A sure sign it is leaking based on my previous experiences. Engine hours are now approximately 375 and the starboard pump is original equipment and has not leaked. I cruise around 20 knots which is well below the rated maximum speed for the engines/boat. Per Mcdonalds I am current on all Volvo recommended engine services.
Has anyone had a similar problem? 3 pumps in 3 years seems excessive. I'm wondering if the failed pump is a result of another yet diagnosed problem although Mcdonalds has seen similar failures in other D600 engines and has speculated that there is a design or quality issue with the pumps. Any help would be greatly appreciated.
