Question 36 Sovran Transmissions
Own a 2004 36 Sovran with straight drives.  Coming into marina, alarms went off and motors cut off.  When trying to power back on one engine was engaged in reverse and one in forward.  Mechanic has gone through everything obvious and cannot locate what could be wrong, so now he is going to pull the transmissions he says, even though when he drained them the oil was perfect, no metal.  Everyone thinks it is odd that both transmissions would have failed at once.
Wondering if anyone here has heard of this or had a similar issue.  Thank you
Hi,
Sounds like your controls, I'm gathering from the year of your boat you have Cummins with Glenndinning controls. Sounds like it might be an electrical issue with the controls.
Highly unlikely it's the trans like tiara 44 said it's the controls, don't let them pull the trans!
Did the mechanic pull the cables and try shifting them manually? How about a pressure test? Both going out simultaneously would be very strange.
  [Tiara Sovran] Synthetic oil for ZF Transmissions. Folkvord 1 1,509 09-18-2023, 11:17 AM
Last Post: Sapphire
  ZF Transmissions firstlight 5 8,562 10-11-2022, 02:51 PM
Last Post: Vic
  2007 3900 Sovran Owners Manual and parts manual ccomeaux 1 2,824 10-11-2022, 01:51 PM
Last Post: Euphoria38
  2009 Sovran IPS Drive Hydralic Pump Problems Opus 2 3,898 09-24-2022, 03:00 AM
Last Post: jgreenlee
  2003 Tiara -- Generator Question sallykropp 2 2,736 06-09-2022, 11:51 AM
Last Post: neto
