Threads: 15
0
Home Port: Seattle
Vessel Info: 2005 Tiara 2900 Crusader 6.0L engines
When I flush the toilet on my 2005 Tiara 2900 does the water come from the fresh water tank or from the lake or ocean water?
Threads: 14
11
Home Port: Kings Park, NY
I believe your head, assuming its electric or manual , uses sea water (salt or fresh depending where you are) unless you have a vacuflush system and then it uses water from your fresh water tank. Easy test is to shut off your fresh water pump(s) and flush the head.
