Sovran 39 Information Needed
Good afternoon all,
Am a former owner of a 2006 Sovran 44 and now looking at a 2007 & 2008 Sovran 39s with IPS 500.
I looked at the boat itself and it will be perfect for our needs in Florida (Bahamas, cruising, etc) but am new to the IPS and Volvo in general. As the boat has been out for about 10 years I would appreciate any advice (good and bad) about it and performance before I make the deal. I am a solid Tiara fan.
Also need info or recommendations for adding a dink lift to the stern, will be using a 11 foot with motors, about 250 lbs. See Sealift all over and they have a great rep.
Thanks for all of your comments.
Bob
(01-24-2017, 03:23 PM)roberthoran Wrote: Good afternoon all,
Bob
Hi Bob.  We just purchased a 2007 39 Sovran with IPS 500s, and just installed a Freedom Lift.    Handles a 11.5 Capelli RIB with 25 HP Honda, and works beautifully.   best of luck!
Excellent, I am concerned about adding weight to the stern and impact on how the boat rides. I'm guessing you have added about 700 pounds to the stern.
Do you reach normal cruise speeds, max RPM etc.
What was done to the IPS systems between new and now, see lots of negativity out there but only way to know is speak to someone who has them.
Thanks again
Bob
(01-24-2017, 06:19 PM)roberthoran Wrote: Excellent, I am concerned about adding weight to the stern and impact on how the boat rides. I'm guessing you have added about 700 pounds to the stern.
Thanks again
Bob
Bob, IPS is great. It takes all the fear out of docking especially in the wind.
There are some things you should look out for on the early IPS Models. Luckily all the shortcomings can be updated.
1. (this is the big one) Have the drive seals been updated to the newest standard? If they haven't the whole drive has to be disassembled to remove the original style seal. Once there updated they can then be easily replaced. Last one I did was $15,000 to bring
2. Have the sea strainers been updated? The original screw on cap style strainers would leak down onto the alternators in the front of the motor. The fix is to relocate/retro a standard sea strainer away from the motor or replace the Volvo strainer with the updated model that uses 4 hand tightened bolts to lock down the sight glass.
3. early motors had a plastic pulley on the front of the engine this needs to be replace with the steel one. Also I'm very sure the idler pulley is supposed to be changed every five years or so and it's not cheap.
4. (big one 2.0) Has the whole cooling system been removed and serviced? If so how long ago? It should be done every 5 years like clockwork. If its been neglected things can get very expensive very quickly. After Coolers are $6500 each and sometimes really hard to find.
5. Make sure to have the drives premiered and bottom painted and propspeed applied to the props. You can loss 3 knots + if you have growth on your props.
6. Have your Volvo dealer quote you the price of your annual service for engines and drives. This should include a haul out.
7. Add the Volvo Line Cutters to the drives in there not on the drive already.
With all this being said I'm a huge fan of IPS and make a good portion of my yearly income selling boats with this system. The cost of ownership is higher but its offset by fuel savings and being able to use your boat as easily as a 13' whaler. People with IPS boats tend to use them much more and never need crew/help with docking.
Just for fun I've included a link to a IPS demo I shot with my drone awhile back. It really shows the system at work.
https://www.youtube.com/watch?v=qS-TyletowM
Best Regards,
Ben
Ben
Some well thought our and appreciate thoughts, I will make sure of the maintenance history before I move forward on any boats. Love Tiaras and hopefully will find the right one with updated pods. Read so much negative maintenance nightmares but also the beauty of docking etc.
Have a great day
Bob
  [Tiara Sovran] 3900 Sovran helm comfort in summer wejonesIII 6 4,124 07-24-2025, 12:08 PM
Last Post: coltsneckbob1
  [Tiara Sovran] Needed 2006 4300 Sovran Owner's Manual floridajack 2 3,501 01-19-2025, 06:33 PM
Last Post: rjbevco@gmail.com
  [Tiara Sovran] Removing Salon Door in 2004 Tiara 44 Sovran Feetwet 4 4,003 06-08-2024, 10:10 AM
Last Post: Feetwet
  Sovran 4300 Performance with IPS600 turbobug56 1 2,554 05-25-2024, 02:11 PM
Last Post: turbobug56
  3900 Sovran Owners Question - Seating in Salon Area minnehahas 2 2,302 05-25-2023, 10:36 AM
Last Post: Donaldjames
