steps
do I need to remove steps to get to shower sump pum. How do you remove?
Some Tiaras place the shower sump below the cabin entrance steps. If your sump pump is located here, then yes, you have to remove the steps to full access this area. There are two inboard cleats (just strips of wood attached to the inside port and starboard edges of the staircase). There are screws going down through the cleats and into the floor (5 or 6 screws on each side). Remove the screws carefully - you don't want to strip the heads out - use the proper sized Phillips bit with an extension if you need to get the proper angle. Once all the screws are out, You should be able to carefully remove the stair case so you can access the sump. Make sure while the stair are out, that you either keep the door locked or make so no one can accidentally enter the cabin and fall.
Good Luck!
  Removing cabin steps in 2000 3500 Open - Can't find anyone who has a real solution... recppd 3 2,576 10-05-2023, 04:41 PM
Last Post: Crown Royal
  [Tiara Convertible] Looking to replace a 12 V light that mounts flush on my steps going down into cabin. Wildstone 2 2,561 12-23-2022, 08:14 PM
Last Post: Trainman
  [Tiara Sovran] Replacing courtesy lights in cabin steps mjcoffin@hotmail.com 10 10,601 08-20-2020, 07:25 PM
Last Post: bsause
  looking for light bulbs for the lights that in the steps to the cabin sluggo 6 6,637 10-27-2019, 03:48 AM
Last Post: bsause
  Any tips for getting the steps back in? NYMarine1 10 10,631 08-16-2017, 07:35 PM
Last Post: trit21
