Removing cabin steps in 2000 3500 Open - Can't find anyone who has a real solution...
So I noticed I had a hose disconnected from the shower sump which was draining into the front bilge and causing a mess.  I can't reach the hose or sump box because I don't have 5' arms and need to remove the cabin stairs.  Can anyone tell me how to do this properly?  There are cleats screwed into the floor along the inside of the staircase, but I've read so many people say that did nothing to get the stairs undone.  I don't have the battery charger or anything else in there that would interfer, except disconnecting the wiring for the step lights.  Any help would be appreciated!
I removed my stairs on my 2002 31 Open. I would imagine they are similar. You do have to unscrew the cleats in the floor. Then there are screws along the right side that attach the stirs to the wall of the head, and there are screws along the top that need to be removed as well. Seems like a daunting task but it was really not that bad.
Remove screws on inside along the floor and inside the stairs against vertical bulkhead.
I have a 2001 3500 open and have taken mine out a couple times over the years. There is a lot of screws but are all reachable and the stairs slides back fairly easily. One guy on here hinged his so he could tilt it out of the way. Another one of those jobs that are easier after it’s done with.
Chuck
  3500 Sovran trimtabs drprunner 0 95 11-14-2026, 03:44 PM
Last Post: drprunner
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 544 08-18-2026, 02:11 PM
