Threads: 45
2
Home Port: Long Island Sound
Vessel Info: 3100 Open, 2002 Model Year, 8.1L Crusaders
I recently purchased a 2002 31 Open. The past owner was getting on in age and was not very good with the maintenance the past few years. When I hauled the boat in the fall I noticed the trim tab Zincs were completely gone. Not a big deal as there isn't any corrosion on the tabs. But the location of the holes for the Zincs will not allow for a standard "Clam Shell" style anode. Someone had mentioned it looked like a "Tear Drop" style anode may have been used. Is there anyone with a 31 Open that can advise as to which kind of Zincs they have on their trim tabs?
Threads: 2
4
Home Port: Lake Michigan
I had good luck matching mine up at boatzincs.com and they were affordable... (I have no affiliation with them)
Max
Threads: 45
2
Thanks for the links. I will check them out. I am on the Long Island Sound but am on the CT side. I will be going to the Defender sale tomorrow I will see what they have. I like the idea of using the two piston holes on the tab.
Threads: 14
11
Home Port: Kings Park, NY
Not sure if Defender sells B&S Zinc's. Know there are distributors on the CT side of the sound. I recommend that you consider using them as they are really a step above all others that I'm aware of..... M2C
