Tiara Open Engine Warning Lights
Twin Crusader 6.0L engines.
When I turn the key on one engine all of the warning lights are supposed to come on briefly so you know that they are working. However the water temp light does not come on. The other three lights do come on and then go off once the engine is started. Once the engine is running the water temp goes up to normal and stays there while the engine is running. Hence I believe that it is a light problem.
On the backside of the dash the lights are on a strip with a single wire connection at each light and a red line connection at one of the lights. I believe that this is a ground for all of the lights. I believe that to replace a light the entire strip must be replaced with the light connections soldered in place.
Appreciate anyones thought on whether my diagnoses is correct, where to get a new light strip and any installation suggestions.
Many thanks
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 6 2,385 11-18-2026, 05:48 PM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,222 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  Engine shut off while running Mydiamond 1 1,144 08-10-2025, 07:51 PM
  31 Coronet "red" check engine light rickturner 0 994 07-30-2024, 07:16 AM
Last Post: rickturner
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,908 10-18-2023, 04:32 AM
Last Post: czarcone
