Tiara Open Crusader gas engine crank but no spark
Posting for information…
My port engine started to crank but not turn over.
No spark from coil to distributor.
Checking posts there were suggestion to;
Change coil
Change rotor
Distributor
Change spark plug and wires
Battery
Etc.
When I jiggled the wire from alternator to coil… the engine would sometimes start.
As I took off the distributor cap and traced the wire, there is a small black piece. I think it’s called the distributor pick up. ( not sure) at the base of the distributor.
Took the two screws out and found it was plugged in to the distributor via a wire connection. This plug was very loose.
Tightened connections… replace piece (just in case). And put back together.
Started right away.
$40.00 piece and was not in any of my on line searches.
I hope it helps someone…
(10-15-2023, 01:42 PM)Mydiamond Wrote: Posting for information…
Change coil
Change rotor
Distributor
Battery
Etc.
Started right away.
Yes, if ECM can't tell engine is turning (due to bad pickup on distributor shaft), it will prevent spark & fuel.
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 6 2,298 11-18-2026, 05:48 PM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,170 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  Engine shut off while running Mydiamond 1 1,104 08-10-2025, 07:51 PM
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,584 06-16-2025, 08:07 AM
  1997 Crusader 454 XLi Service Manuals TiaraTom 4 5,065 01-16-2025, 08:59 AM
Last Post: dthelen40
