Where is the switch for the fresh water wash down?
I am new Tiara owner (2003 35 open with twin Cummins) and appreciate the tips and suggestions on the forum.
As I go through the boat I found a dual hose fitting in the aft port corner. One fitting is marked raw water wash down and I have found the rocker switch for that. The other is marked fresh water. Where is the switch to turn that on and off? The owners manual does not locate it either.
Thanks in advance
Steve
Have you checked the 12 volt panel for a breaker for raw water washdown?
Sorry did not read your post properly. Fresh water wash down is operated off the fresh water pumps. As long as your fresh water system is pressurized the wash down will work.
There is no separate switch for it.
thanks
Finally solved the mystery.
The fresh water wash-down has a compression fitting similar to an air hose. When you plug it in, water flows
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 947 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,538 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,326 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,862 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,793 06-22-2025, 02:18 PM
