Mounting TV in 3100
Hi all - does anyone have experience mounting a flat panel TV in a 3100 cabin, specifically in the space above the electrical switch panel (starboard side, right above aft portion of cabin seating)?
Right now there's just a smoke detector there. I want to mount a 32" tv there, but wanted to understand how to best to mount.
THanks all
There is an earlier thread about mounting a TV in a 3100 Open. You might want to jump on that thread to ask about your specific request.
Tim
(07-11-2017, 01:24 PM)rexmobile Wrote: Hi all - does anyone have experience mounting a flat panel TV in a 3100 cabin, specifically in the space above the electrical switch panel (starboard side, right above aft portion of cabin seating)?
THanks all
I actually mounted mine on the bulkhead closet (depending on your models yr, mine is a 98).  I used  a swing are with anchor ties on the bulk head. This allows me to watch in bed or rotate it to watch form the dinette.  There is more than enough structure to support the are and all cable / power was there for the old 12 v TV original to the boat.
It was also easy and clean to route the cables to the arm via small hole and a chrome clam shell vent cover to hide the hole.
Hope this helps!
(09-08-2017, 04:14 AM)tburling1958 Wrote: There is an earlier thread about mounting a TV in a 3100 Open. You might want to jump on that thread to ask about your specific request.
Tim
THanks all
Good Morning - Nice installation I had a couple of questions. What size tv did you install and any info on the arm.
john
I'll get the specs and post shortly!
  3100 fishbox ideas? waggles02673 1 2,417 06-10-2023, 07:38 AM
Last Post: ReelEnjoyment
  [Tiara Coronet] 2013 3100 Coronet - How to add Engine RPMs and Fuel Flow to Garmin GMI 10 Display tjmoberg 1 2,409 06-10-2021, 12:26 PM
Last Post: August Rush
  Transom Door Install 3100 Open Redarrow32 5 5,280 05-03-2021, 12:01 PM
Last Post: Duke
  [Tiara Open] Helm & Switch Panel Refurb (1986 3100 Pursuit) - the helm part emarrero 0 1,920 11-11-2020, 04:00 PM
Last Post: emarrero
  [Tiara Open] Helm & Switch Panel Refurb (1986 3100 Pursuit) emarrero 0 1,770 11-11-2020, 03:10 PM
Last Post: emarrero
