Shower sump pump
I have a 2006 36' open where does the shower sump pump discharge water out of boat. Thanks
I have a 97 3700 Open and it goes into the gray water tank. The gray water tank has 2 pumps, primary that sits on top and a secondary in the tank. I just had to replace the float switch on the primary pump. I have heard that some models pump directly over, some into a gray water tank like mine. Check your owners book, it should have that info in it.
Our 3200 open pumps shower water overboard a couple feet forward of the head. The sump pump is located under the stairs to the cabin and discharges a/c condensate as well. Galley sink discharges overboard through another fitting located on the port side just a little forward of the shower fitting. The 3600 opens are similar.
  Water around the shower sump robh19 3 2,681 01-01-2022, 07:21 AM
Last Post: Capt. Tom
  [Tiara Sovran] 2008 Sovran 3900 AC Raw Water Pump Relay location bbisland 1 2,409 12-21-2021, 10:40 AM
Last Post: Skipper747
  [Tiara Open] Water in hull under stair & fresh water pump brijeski@optonline.net 8 9,235 09-03-2019, 12:52 PM
Last Post: Duke
