Tiara Sovran Salon air
I would like to know where is the pump relay panel on a 2013 sovran 39
My 43 has the pump relays located in the ER right next to the condenser control boxes . Should be a small box with a wire leading to the pump and separate wires leading to each control box. If you can't find it trace the wire back from the pump. It will terminate at relay or a control box (if only serving one system). If your boat has self contained (not split gas) units it's possible the relay is mounted next to one of the cabin systems.
  [Tiara Sovran] Removing Salon Door in 2004 Tiara 44 Sovran Feetwet 4 3,986 06-08-2024, 10:10 AM
Last Post: Feetwet
  3900 Sovran Owners Question - Seating in Salon Area minnehahas 2 2,290 05-25-2023, 10:36 AM
Last Post: Donaldjames
  2004 52 Sovran Salon upper salon headliner replacement Knot On Call 3 4,528 07-20-2020, 12:08 PM
Last Post: Knot On Call
  Tiara 3000 Open salon berth Flatliner 0 1,699 05-11-2020, 08:26 AM
Last Post: Flatliner
  Need salon table base and posts Metyson1 5 6,369 12-29-2018, 09:31 PM
