Threads: 6
0
Home Port: Georgian Bay and North Channel of Lake Huron
Vessel Info: Tiara 4000 Express Cruiser, 1997, Twin Cummins 8.3 Diesel engines
Good day all; I have heard of automatic engine oil change systems. How would I know if I have one in my new-to-me Tiara 4000 Express Cruiser 1997? This boat seems to have a lot of optional equipment? Any info will be appreciated! Fuzzdr
Threads: 3
20
Home Port: Lake Michigan
There should be a breaker on the main distribution panel for the oil change system. There also should be a pump and manifold (usually on the ER bulkhead) with 5 oil lines attached along with valves for each engine, gear and generator. If you look at the bottom of the oil pan you should see one of the oil lines coming out where the drain plug would be. Follow it to the pump.
Threads: 6
0
clark 003 thank you for your thread on automatic engine oil change systems. The next time that I visit my boat, I will be sure to search for the things that you have mentioned. Fuzzdr
