Tiara Open Syncronization System problem
The synchronization control is faulty. When the Sync. switch is activated the "Slave" [port] lever goes slack, but the starboard lever does not control both throttles, as intended. Then when the "sync." is turned off, the starboard throttle lever still is slack and does not control the port engine. So, port engine RPM's remain at idle speed.
Any suggestions?
Glendinning has exceptional telephone customer service....but you need to play a little trick to get a tech right away. Go straight to the operator and ask if she would find anyone for a quick question.
is Glendinning the Sync. System maunfacturer?
Yes. And second Geo’s comment. They are an amazing company!
  Tiara Coronet water tank fill problem d5dekeyser 1 1,780 06-07-2022, 08:26 PM
  does anyone own a Tiara from like 2009 etc that had the Volvo pod drive system sluggo 3 6,145 07-12-2020, 12:19 PM
Last Post: bbisland
  Automatic Oil Change System Fuzzdr 2 4,531 07-06-2018, 11:53 AM
Last Post: Fuzzdr
  Exhastu system nukey99 7 9,351 11-23-2015, 06:12 PM
Last Post: bluebikemike
