Instrument panel replacement for new electronics
Hi all - I’m refitting a 1993, 3100 open and planing for new electronics to replace the raymarine C120. I will have to replace the dash panel with a new piece. Looking for recommendations on materials that will match fairly closely or a company that makes replacement panels.
Thanks for the help
We have a 32 Open and replaced all of the electronics about three years ago. The yard used a heavy gauge aluminum sheet with the correct openings. It is powder coated in grey and the trim line and Tiara logo are silk screened on it to match the appearance of the panel from the factory. Tiara uses aluminum in addition to fiberglass on a lot of it models, so we did what the factory did when it built the boat.
I have the same problem, 3100 open. I am hoping I can find an installer that can find such a replacement plate. If anyone has a link or specific supplier, please post. OP did you have any luck finding a replacement?
(07-28-2018, 10:04 AM)SeaJules Wrote: I have the same problem, 3100 open. I am hoping I can find an installer that can find such a replacement plate. If anyone has a link or specific supplier, please post. OP did you have any luck finding a replacement?
We replaced our Raymarine E-series on our Sovran with Axioms.  Given the size difference, our installer had these plates made to sit under the new ones...Black resin with smooth edges and slight texture on top...they almost completely go away under the Black Axioms.   Rob Cook is a Raymarine installer in Benton Harbor, MI (rcms@triton.net).  He did the work on the electronics and has a supplier for the custom plates (i think the cost was $125 or so for two?).  Couldn't be happier with the result.   He's a really good guy. Good luck![attachment=437]
I replaced mine in my 1989 31 Open with new custom panels from Tecnografic inc. in Ft. Lauderdale.  www.tecnografic.com
It wasn't inexpensive but more than worth it.
Ask for Sam, he will remember working with me.
            I have a 1996 31 Open. Had same issue, by the time you remove the old instruments, there are many holes o fill. I found a company who made the 3/8" black plate to my specifications and routed the edges. Added a Garmin 7612xsv, HD thru hull transducers, Garmin Fantom 24 dome, and updated the old Raymarine autopilot. Gives me a wide open canvas to work with.
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 543 07-25-2026, 09:15 AM
Last Post: roboh20
  [Tiara Coronet] Port engineer and electronics quit running at same time Tmikac 3 995 07-07-2026, 07:47 AM
Last Post: Tmikac
  Freezer Replacement for 40' Tiara Reprise1 4 2,080 06-09-2026, 02:28 PM
Last Post: fuzzy
  Removing Wall Panel on other side of helm on Sovran 3500 no shocks 1 1,184 02-15-2026, 03:38 PM
