43 sump box pump
Question
Hi all,
Recently purchased a 2002 43 open.  Curious as to why the sump box pump continuously cycles on and off, even when there is no shower or sink water running to it?
Chris
Not sure which pump is installed in the sump but RULE makes a pump (500) that cycles automatically every few minutes to see if water is present to pump. If not it shuts off. You may have that pump.....
Depending on how often it cycles, it could also be that an AC condensate drains into the sump box as well...
I have a 4300 as well. Maxwell is correct in that both ac condensate drains into that sump box. Depending on how often the pump cycles that may or may not be what is going on. There is also a check valve on the pump drain line that if faulty, lets a bunch of water drain back when the pump shuts off. That will cause it to short cycle.
Easy to find out. Pull the cover off the box and see which line the water is coming from
Thanks all- going to investigate in the morning
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 3,102 08-21-2025, 08:28 PM
  Power issue livewell and oil change pump smagistro 1 883 04-22-2025, 06:07 AM
  2002 - 31 Open AC Pump Issues Matta0413 2 1,920 08-12-2022, 09:13 PM
  [Tiara Open] Shower pump mold Tiara 38 open 4 2,852 06-27-2022, 11:52 AM
Last Post: Sapphire
  1996 Tiara 40 Express Forward Head Shower Sump Box Randybeach@windstream.net 3 3,339 09-27-2021, 09:22 AM
Last Post: August Rush
