Power issue livewell and oil change pump
Hi I have no power to the live well the macerator or the oil change pump when the breaker is on for it. Wondering if there are inline fuses or if I should be running a new feed and ground to them. Boat is a 1999.
There should not be any inline.fuses after the breaker. Find a good ground and check the power at the pumps. I had a couple of pumps go out on me and it was the ground wire. I kept checking the power by attaching into the bad ground wire and of course it didn't show power.
I went to the breaker and started tracing from there. Because I had changed to a different ground, I showed power all the way to the pump. That's when I changed the grounding from the pumps and everything worked. Drove me nuts for awhile.
Every since then, I start at the breaker and run a long wire from a known good ground to assure I have a good ground. and start checking from there.
  Looking for Help with Fuel Vent Issue - Tiara 2700 (1988) kahunamax 3 630 10-02-2026, 11:50 AM
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 3,097 08-21-2025, 08:28 PM
  Reinstalling power vent in windshield. 1993 3100 open barefoot446 2 1,342 06-15-2025, 08:09 PM
Last Post: penneyma
  [Tiara Sovran] Shore Power Cable Replacement wwaseleski1953 2 1,443 06-12-2025, 07:50 AM
  [Tiara Open] Electrical Issue: Some helm switches not working twilson0929 3 1,703 04-24-2025, 09:03 AM
