Threads: 9
1
Home Port: Great Lakes
Vessel Info: 2006 Tiara 3200 Open
8.1L Gas
Can anyone tell me where the stereo amplifier (for the cockpit speakers) is located on a 2006 3200 open? It is the factory Clarion system. I have an issue with bad static in the cockpit only that I suspect is related to the amp or an amp ground. Thanks for the help!
Threads: 3
0
Home Port: south haven
Vessel Info: 2006 3200 open 8.1 crusaders
Its in the cabin behind the wall forward of the steering station. There's four screws holding a wood partition just above the a.c. unit.
Threads: 9
1
8.1L Gas
Thank you. Appreciate the help. No I have to decide to tackle now or wait until spring.
Threads: 3
0
Check the condition of the speakers themselves, often high heat and humidity can destroy the material around the cones as it did in most of my clarions. Also I notice when on shore power and using the tuner for local stations theres alot of static but as soon as I unplug from shore it goes away. Had the same issue with other boats.
Threads: 9
1
8.1L Gas
Thanks for the reply. I did replace the speakers already with JL Audio units and “sometimes” it sounds great but sometimes a lot of static. Static is present even on aux input and even when muted. It seems like a bad ground or amp but I’ll check it out. Appreciate everyone’s input.
Threads: 1
0
Home Port: Long Island sound, Cape Cod
Vessel Info: Tiara 3000 Open 2007
8.1 mpi
Same problem
07 3000. Open
Interested to hear more
Threads: 0
0
Home Port: Southern California
Trying to do the same thing on my 3600. I would assume it was in the same spot. Any pictures?
Threads: 0
0
Found the amp forward of the helm in the cabin. I needed to remove the back of one of the banquet seats aft. the back had 2 screws securing it behind the seat cushion. This exposed a panel with 8 screws. The amp was behind the panel mounted to the port side wall.
Threads: 9
1
8.1L Gas
Thanks everyone. We are in Michigan so won’t be unwrapping the boat for another two weeks. Hopefully will find something obvious when I look. I will post results. Please update with your findings as well. I’m expecting to find a ground or moisture issue or the need to replace the amplifier.
Threads: 1
0
8.1 mpi
I replaced my exterior speakers, (only have static on them) sound/ static is much better. Next to be changed is corroded speaker wire at connection to speakers, I will post update
