DC Panel Selector Switch for 3500 Open
Looking for a replacement meter select switch for my DC panel (switches between house and engine).   I have a 2000 3500 Open.  Thanks!
I don't have a recommendation as to replacement switch, but I can tell you that since I installed a Balmar SG200 Battery Monitor in my DC panel on our 2004 3500 Open, I never use the rotary selector switch at all to check my battery voltage. The monitor tells me so much more than just voltage.
By the way, that analog meter that's in the panel consumes a surprising amount of power if you leave the selector to either one of the choices rather than off. Check out the Balmar monitor. It's simple to install. I removed the lower right side rectangular plate from my panel and used a hole saw in a drill press to bore a 2-1/8" hole in it to mount the gauge to.
Thanks Dave.  Excellent suggestion!
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,664 07-15-2026, 08:06 AM
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,565 03-24-2026, 09:46 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 3,016 11-14-2025, 01:01 PM
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,778 11-07-2025, 02:50 PM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,992 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
