31 Open Bed question
I bought a 96 31 open and have a question on the stock bed cushion configuration, my boat has a large hinged cushion that looks stock. It has a small almost square cushion that is in the same Ultra Leather as the dinette cushions and a second kind of triangular shaped cushion that looks homemade both sit on individual wood supports and fill in the gap by the dinette and cover a storage area. Does anyone have a picture of the stock set up or dimensions of the original cushions (the small ones?) picture attached
Hi Silver R
I have a 98 31 Open, Compared to my set up, the triangular element looks to be a Custom addition. Mine has a straight across cushion that allows the closet to open a full 90'. This cushion and the backer board are removable to allow easier access and step up the bunk. When the cushion and backer are removed there is also a little seat (outboard) which is covered by the small leatherette covered element (again with storage below). Looks like a custom job to create a little more bunk space.
My rig is in the warehouse for the season, but I'll make it a point to get a couple of pix in the next few weeks.
Thanks, I want to return it to stock as my wife bought sheets and the small section of fitted sheet does not fit on the custom cushion in my boat.
Paul
This is a photo of the factory berth filler piece. This was an option and was not standard. As you can see, it goes straight across and does not angle back.
[Image: DSC01463.jpg]
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 661 11-16-2026, 01:54 PM
  [Tiara Open] 36' Open interior lights Rick B 0 133 11-14-2026, 12:22 PM
  38 open bathroom recessed light bulb twilson0929 3 735 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 567 08-18-2026, 02:11 PM
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 761 08-17-2026, 05:31 PM
Last Post: Bford100
