08-14-2019, 01:29 PM
I have 31' Tiara 1999 with 454xli crusader engines . Port engine i keep getting hot while cruising at 3000 rpm . But not at the dock . Only when WOT . New risers in 2015, new pump last year , brand new impeller , 2018 new oil cooler . She runs perfectly fine even higher rpm at the dock with out getting hot . Only in gear at higher rpm 3000k she is getting hot, getting trans temp alarms and engine as well . Any advise to where to look at this problem would be great.
Thank You
Al
Thank You
Al
