38 open 2001-fishbox/livewell overboard macerator pump out
2001 38 open have a fishbox & a "livewell" in deck just in front of the transom.
How can I plump the fishbox to an overboard macerator pump?  In know that I will need a through hull fitting.
How can I plump the "livewell" with a raw water supply & overboard discharge to constantly circulate the water in the "livewell".
Is it better to use a diaphragm macerator pump?
Thanks for the help, Andy
On my 36, my fish box has long hose (so I can remove the box) that goes into a pump that goes into a thru hull out the bottom of the boat. There is a switch just under the rear gunnel. Switch up fills the fish box with sea water. Switch down empties the sea water from the fish box.
What pump is it: make/model?
I'll snap some photos next week when I'm up and get the model and information about it.
Thanks so much!
First photo shows the thru hull, pump, and hose up to the back of my fish box.
second photo shows the pump, it's a Jabsco, model 18870-0123
Third photo is the switch just inside the gunnel on the stern.  In the up position, it fills the fish well, in the down position, it drains the fish well.
Will that pump move fish scales & other fishing debris?
(08-24-2019, 01:12 PM)OurHighLife Wrote: Will that pump move fish scales & other fishing debris?
Yes, I think we had a 3" emerald shiners go thru it today to!
When something does seem to get stuck in there, I just run it in fill for a few moments and then empty again and it's fine. I have yet to get something stuck in there that caused a problem that I couldn't work loose.
How about the in deck live well? Water in & overflow?
(09-12-2019, 04:31 PM)OurHighLife Wrote: How about the in deck live well? Water in & overflow?
I do not have a live well hooked up in mine. Just use those for storage.
  [Tiara Open] Cabin Laminate Repair- 3300 Open Boatworks 1 82 11-17-2026, 03:49 PM
Last Post: joshuawhite
  Adding a generator to a 3500 open Simpleg1 1 2,009 09-09-2026, 06:53 PM
Last Post: penneyma
  [Tiara Open] Extend Swim Platform 1988 36 Open tomconroy 4 5,156 02-07-2026, 12:15 PM
Last Post: jgaudet2
  Adding a Live / Bait Well to my 3200 Open ove.schuett@comcast.net 1 1,568 07-07-2025, 06:55 PM
Last Post: Woodworker2001
  [Tiara Open] Larger and Smart TV for 2006 3600 Open Trainman 1 2,322 06-18-2025, 03:20 AM
