502xl crusaders - timing/knock sensor
Bought a 94 3600 open last season with 502xl motors in it, we are doing all the maintenance during the off season and a friend with the same boat mentions hit mechanic got info from crusader about disconnecting the computer and advancing the timing for better performance and fuel burn, something about the knock sensors going bad and pulling out timing. Does anyone know anything about such a thing, and if so have any details.
Cpt. Carl
Mercruiser 502's of that era have the knock sensors wired in as a separate component to the ignition module. Pretty sure Crusader does it the same way. The knock sensor rolls back the timing curve when it detects engine knock or misfiring. pretty sure you can rewire the harness that runs between the coil and ignition amplifier to bypass.
ive seen those knock sensors throw the best of mechanics for a loop. Once had a minor engine miss that caused a drive plate harmonic. Nothing you could hear but the knock sensor picked it up and would roll the timing back, making the problem worse until it wouldn't even run. Found it only because we threw in an old ignition amplifier that bypassed the knock sensor and the problem went away.
IMO I wouldn't push the timing. It's not going to give you much in the way of performance or economy and in a boat it's very difficult to hear detonation. There is a reason the factory set it where it is.
  need exhaust t for 502xl engines louie d 0 1,373 03-04-2025, 06:26 AM
Last Post: louie d
  [Tiara Open] Tiara 31 open crusaders getting when WOT aliyilmaz 5 6,610 03-03-2025, 07:40 PM
  [Tiara Open] What temp should my Crusaders run? tremont58@yahoo.com 6 5,438 06-29-2023, 02:37 PM
Last Post: TiaraTom
  Raw water temp alarm on closed cooling crusaders cp4000 0 1,266 05-30-2023, 03:15 PM
  1993 2900 Open, 350 Crusaders Maintenance & Replacement ?? 29opensoon 2 3,841 12-15-2022, 02:00 PM
Last Post: Misdirection
