Outdrive cover - bottom painiting
[attachment=590][attachment=590]Hi - I've stripped my hull of all the bottom paint but came across a cover for the outdrives (both metal and fiberglass as shown in the picture). Does anyone know what's under it and if I should remove and clean before repainting the hull?  I don't want to open a can of worms but want to make sure I do the right thing.  If so, there's a sealant on the edge & what's used there as well.
Appreciate any advise - thank you!
John
I would remove them and paint everything in there. Just because it is covered doesn't mean nothing will grow in there. I will bet if you use a light and look in you will.see older paint in there.
And I think those are your prop shafts, not out drives, just so you know the correct terminology.
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 1,034 12-14-2025, 05:34 PM
Last Post: MariTime2
  [Tiara Sovran] Piston to hold up sink cover cjh3500 2 1,484 09-13-2024, 09:09 PM
  2006 Tiara 2900 cover for sink and stove 4gallaghers 2 1,992 08-28-2024, 09:10 PM
Last Post: TenBayFive
  [Tiara Coronet] Vent Cover NPCP-SP 2 1,358 08-08-2024, 07:20 AM
Last Post: NPCP-SP
  2005- 3600 Open Center Windshield Wiper Motor Cover Replacement Tminus3 1 1,409 03-30-2024, 08:03 AM
Last Post: Makoman
