31 Open bait station cover supports
I have a 1996 31 open with the bait station behind the captains seat. The plastic lid is in great shape but the hardware that holds up the top to access the sink is old and does not work well. Has anyone replaced these supports with something better like gass props or and electrick lift?
Those supports are still available. Just replace them.
\"Buoy Scout\"
Tiara can help with replacements or where to find them
Was hoping to get something better there are 2 on the lid and you need to turn a little gear to onlatch them just thought gas props would be better solution
You don't need to turn a gear to open them if they are in sync. Just lift all the way to the stop and set down. Then lift all the way to the stop and gently lower all the way down. They get out of sync if you lift one side with more pressure than the other. Then they get out of whack and cause issues.
The problem with gas struts is you are going to have to make perfect measurements for the proper angles and get just the right pressure struts in order for them to work properly. Unless you are extremely mechanically inclined, I would not bother or your are going to wish you had never tackled the problem.
The original stainless mechanical latches work great if you keep them straight and lubricated and open and close the hatch evenly with even pressure.
Good Luck.
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 627 11-16-2026, 01:54 PM
  38 open bathroom recessed light bulb twilson0929 3 717 08-26-2026, 06:22 AM
  2001 38’ Open interior table base removal twilson0929 3 997 07-07-2026, 08:13 AM
