Port charges house or port charges starting batteries
I have a 2002 31 Open and I cannot remember which engine charges which bank of batteries. Can anyone remind me? Thanks
Port charges house. Starboard charges engines batteries.
Thanks - much appreciated
(04-29-2020, 08:41 AM)Misdirection Wrote: Port charges house. Starboard charges engines batteries.
I had the same question on my 1996 31 open. Is it the same for the 1996 year?
I'm pretty sure it is for your boat as well. The easy way to confirm is to place a volt meter on your house battery and start the port motor and increase rpms to above 1500. You should see the volt meter increase in voltage, most likely to 14.4v. If you have a parallel switch connecting your house and starting battery, make sure the two batteries are not connected thru the switch during the test.
thanks for the quick reply
  [Tiara Open] 1994 3100 Open Number of Batteries Duke 3 3,473 01-27-2024, 03:33 PM
Last Post: Joeboch348
  [Tiara Sovran] Charging batteries at the dock or on the hard Donaldjames 3 3,643 05-13-2022, 11:45 AM
Last Post: Donaldjames
  2004 3600 Sovran weak starboard starting Tantram 2 2,560 01-27-2022, 02:17 PM
Last Post: neto
  Batteries Folkvord 8 5,893 10-30-2021, 09:21 AM
  8D House Battery Bigdrew 0 1,501 12-01-2020, 11:45 AM
Last Post: Bigdrew
