2004 3600 Sovran weak starboard starting
Greetings,
My starboard engine is having a tough time starting, and I think it's likely a bad battery since it turns over just fine if I enable the crossover.
I dropped my head down below to check out the batteries and was a little overwhelmed, not knowing which battery goes to what or even how to get them out of the tight space and replaced.
Is there an idiot's guide to the battery layout or some tips and tricks that may point me in the correct direction?
Thanks for listening to an idiotSmile
First thing to check is the terminal connections. Make sure they are clean and tight. If all is well there you may have a bad battery (or two) on the starboard bank of batteries. Turn off rhe battery charger, disconnect the negative cable and load test each one individually. That will tell you which one's are going bad.
How many battery banks do you have? If only two (Engine bank and House bank), try tracing the starter wire and verify its connected to the same place your other engine's starter is taking the juice... It could be that that specific starter is connected to the house battery bank and those deep cycle batteries have much less cranking amps to start an engine, much less a 450C. If they are indeed connected to the same bank, then my next move would be to clean terminals and try again. What starter do you have? 38mt or 42mt?
  2006 Tiara 3600 Sovran Stereo Question. Final Pursuit 0 811 10-25-2025, 03:53 PM
  Inverter- How to use and location 39 Sovran August Rush 3 1,955 09-02-2025, 09:49 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 895 08-09-2025, 07:49 AM
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,119 11-10-2024, 09:17 PM
  2007 39000 Sovran Engine Hatch Won't Lift Kevin Spellman 3 3,671 08-04-2024, 03:16 PM
Last Post: rcwiegand
