2007 39000 Sovran Engine Hatch Won't Lift
Hi all, I've read some older boat threads about the engine hatch lifts having special safety elements. Ours won't lift and we have spent hours trying to figure it out from an electrical standpoint. Any ideas??
Thanks,
Kevin
(05-28-2021, 07:53 PM)Kevin Spellman Wrote: Hi all, I've read some older boat threads about the engine hatch lifts having special safety elements. Ours won't lift and we have spent hours trying to figure it out from an electrical standpoint. Any ideas??
Thanks,
Kevin
I have an ‘08 32 Open and had to replace the Magnetic Reed switch under the companion seat. It only cost about $10 (the shipping was more than the parts) but was a bit of a hassle finding the right parts. I replaced both the sensor and actuator. I eventually found the exact ones at this place, Allied Electronics.https://www.alliedelec.com/view/search/?...%2f3886800 I kept the invoice with the part numbers etc. and can give them to you if you need them. Took 2 minutes to do.
Thanks,
Kevin
Hi,  yes, Please send me the part numbers
Thanks,
Kevin
Did you get the part number?  I have the same issue.
Thanks-
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,524 03-24-2026, 09:46 AM
  2006 Tiara 3600 Sovran Stereo Question. Final Pursuit 0 810 10-25-2025, 03:53 PM
  Inverter- How to use and location 39 Sovran August Rush 3 1,954 09-02-2025, 09:49 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 894 08-09-2025, 07:49 AM
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 1,029 06-15-2024, 07:50 PM
