Tiara Open 3800 Window frame crack
I own a 2001 3800 open.  Absolutely love the boat and, other than my window frame problem, it's in perfect condition.  The fiberglass frame around the operating window has crack on all three sides (port, starboard and top).  The crack is very uniform as if a seam failed.  I don't know if it's from stresses incurred underway (I have a factory hard top) or if water inundated it and expanded the fill material.  The boat is presently at a boatyard here in Newport Beach and so far, no one there seems to have a clue how to fix it.  I know removing the operating window is probably a no-no (based on other posts in this forum), but it doesn't seem that complicated, once you figure out the right glue/epoxy to use, to get sufficient pressure to re-seal the crack.  Has anyone on this forum incurred this same problem?  Thanks in advance!
Pictures attached (I think).
(06-16-2020, 06:45 PM)Tom_marshall@catellus.com Wrote: I own a 2001 3800 open.  Absolutely love the boat and, other than my window frame problem, it's in perfect condition.  The fiberglass frame around the operating window has crack on all three sides (port, starboard and top).  The crack is very uniform as if a seam failed.  I don't know if it's from stresses incurred underway (I have a factory hard top) or if water inundated it and expanded the fill material.  The boat is presently at a boatyard here in Newport Beach and so far, no one there seems to have a clue how to fix it.  I know removing the operating window is probably a no-no (based on other posts in this forum), but it doesn't seem that complicated, once you figure out the right glue/epoxy to use, to get sufficient pressure to re-seal the crack.  Has anyone on this forum incurred this same problem?  Thanks in advance!
HI CAPT,
I HAD SAME BOAT AND YEAR...  THIS IS A NEW ONE.  I WOULD CALL A GOOD FIBERGLASS MAN IN YOUR AREA.
GOOD LUCK, ALSO TALK TAYLOR MADE THEY MAY BE ABLE TO HELP TOO
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
www.themarineminute.com
Thanks for the quick response.  I'm not familiar with Taylor Made.  Is that a fabrication outfit?
Taylor made makes the window frames. I would email Tiara with your HIN number explain your problem and they can probably point you in the right direction.
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 869 05-12-2026, 10:18 AM
Question [Tiara Open] Window support/slides? mrkrothfuss1 3 1,287 07-31-2025, 12:01 PM
  [Tiara Open] Center tip out window Remington 4 1,627 04-07-2025, 12:33 PM
  2000 3500 Express - Powder Coat on Windshield Frame Touch Up JMGCINCY2023 0 833 03-19-2025, 07:47 PM
