Tiara Convertible 1996 454 Crusader Fuel pump pressure switch
Hi all, I have 96 31 open and had a motor suddenly quit while out on the high seas and forcing me to return to port on a single engine. I see in my Crusader manual there is a troublesome switch called the fuel pump pressure switch that cuts off power to the fuel pump when oil pressure is lost. I spent a couple of hours searching the high and low before coming to the conclusion that my Tiara does not have these fitted to my motors. During the search however I discovered the electrical tab on the oil pressure alarm had corroded completely off. I replaced it and the engine fired right up and runs perfectly now. I don’t see anywhere this new configuration is documented. Does anyone know if this is factory?
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 6 2,309 11-18-2026, 05:48 PM
  Upgrading to fuel injection Joeboch348 1 1,360 11-26-2025, 12:14 PM
  [Tiara Open] Raw fuel smell while running WOLFDAWG71 3 1,644 11-19-2025, 07:43 PM
Last Post: Joeboch348
  Fuel Filler Hose Joeboch348 1 1,085 08-18-2025, 04:24 AM
Last Post: Capt. Paul
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,585 06-16-2025, 08:07 AM
