Threads: 11
1
Has anyone had issues with a main disconnect switch going bad? I recently needed to re-set my Raymarine system to get the radar to connect. I turned the house main off (under companionway steps) but the power didn't go off. Did it a few more times and finally got it to cut out. Is this switch something that fails and can be replaced?
Threads: 8
10
Home Port: Port Canaveral, FL
Vessel Info: 2003 Tiara 50 Open
3406E Cats
Not sure what boat you have but those mains should be exercised every so often. I work mine every month or so when I do my seacocks.
Post a picture of the switch. I am sure it is available online.
Threads: 11
1
I looked really closely on the red key and it appears to be a Hella Marine Battery switch. Looks like I need to disconnect the batteries and remove the entire panel in order to replace the switch. I would post a photo but it appears photo posting on this site has changed and I need to figure out how to do that.
Thanks!
