Bulge alarm on 2008 Sovran
Is there a high bilge alarm, where are the sensor(s) and alarm Audio?
We own a 2009 Tiara Sovran 3900 with IPS, the high water alarm is located inside the galley cupboard ( eye level) just to the right of the sink. It has a switch on it for on /off and test mode. The Audible alarm is located on the assembly next to the switch )The sensor I believe is located near the aft bilge pump but not part of that unit. The alarm as I understand it kicks on ( Alarm only)if the aft bilge is not working .
Thanks for the reply. I did find the switch, in the galley/salon lower cabinet. Looked in the area near each bilge pump can’t find the sensor, will keep looking.
(11-06-2020, 10:31 AM)Donaldjames Wrote: We own a 2009 Tiara Sovran 3900 with IPS, the high water alarm is located inside the galley cupboard ( eye level) just to the right of the sink.  It has a switch on it for on /off and test mode. The Audible alarm is located on the assembly next to the switch )The sensor I believe is located near the aft bilge pump but not part of that unit.  The alarm as I understand it kicks on ( Alarm only)if the aft bilge is not working .
Do you still need a picture of the sensor? If you do I can provide you with one just reply to my email:
donaldjames1990@gmail.com
  2006 Tiara 3600 Sovran Stereo Question. Final Pursuit 0 817 10-25-2025, 03:53 PM
  Inverter- How to use and location 39 Sovran August Rush 3 1,960 09-02-2025, 09:49 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 900 08-09-2025, 07:49 AM
  2007 39000 Sovran Engine Hatch Won't Lift Kevin Spellman 3 3,673 08-04-2024, 03:16 PM
Last Post: rcwiegand
  [Tiara Sovran] 2004 52 Tiara Sovran Salon Charles Ind. Master Controller ACMC 50I-1 Knot On Call 2 2,324 05-21-2023, 08:32 AM
