Tiara Open Engine Make
I have a 1996 Tiara Open with a gas powered 454 Crusader 7.4 MPI Engine.   It is my first year with the boat and i am starting to winterize and called to get oil and filter spec.  Marine west asked me if the engine block is a chevy or a ford. how do I determine what blocks Crusader was using in 1996?   Plan on using Rotella 15W40 oil.  Appreciate any other advice on anything special to winterize (drain water, blow out lines, etc all on the list). Thanks.
If it is a true 454, Chevy, Ford made a 460 but I don't think they ever made a 454. But, if so, I will stand corrected.
A Fram PH8A (or comparable) oil filter and Rotella 15W40 will work just fine; as mentioned its a Chevy 454 block.
If its raw water cooled, drain the water from the block, manifolds, and pull the pencil zinc and drain the oil cooler. Pull off the cooling hose at the thermostat and pour in some Pure Oceans -50 antifreeze.
Make sure to get the water out of the raw water strainers if you dont run antifreeze thru them.
thanks to all for your comment!
These engines are GM. I have the same year in a 29 Open. Recommended oil weight is  straight 40.
(10-24-2020, 08:52 AM)roboh20 Wrote: These engines are GM. I have the same year in a 29 Open. Recommended oil weight is  straight 40.
Tractor Supply has a great price on Rotella 40W!
I use 51515 Wix Oil Filter
[Image: NBvUYCDdQEqZfboL8]
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 6 2,384 11-18-2026, 05:48 PM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,221 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  Engine shut off while running Mydiamond 1 1,144 08-10-2025, 07:51 PM
  31 Coronet "red" check engine light rickturner 0 993 07-30-2024, 07:16 AM
Last Post: rickturner
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,906 10-18-2023, 04:32 AM
Last Post: czarcone
