Shore Water Hookup Leaking Into Hull
I haven't hooked the boat to shore water supply until recently at a slip. I notice the bilge pump come on a few times & thought that was strange since I usually don't have much water in the bilge. After the weekend, I noticed the boat listing to the side where the water hookup is. I'm thinking there must be a leak in the water line somewhere and the water is built up & only coming out slowly. Wondering if this has happened to anyone else?
I'm guessing the water will continue to leak out of where it's trapped, eventually but, I have to pull the boat out of the water next weekend. I guess I should plug a solar panel into the system to keep the batteries charged so the bilge pump can continue to pump out the water? Any thoughts on this?
Do you have a similar problem when the fresh water pumps are on? Does the fresh water pumps come on for a few seconds every once in a while even if no one is using a faucet?... Had a problem last year when the fresh water was hooked up to shore water only. Turned out the water inlet regulator was leaking on the back of the regulator (dripping) when hooked up to dockside water only...  When running the fresh water pumps for water there was no leak.. I'm guessing your fresh water supply fixture/pressure regulator is leaking on the rear. I attached a link to the what I believe is defective. M2C
https://www.wholesalemarine.com/shurflo-...qMQAvD_BwE
A simple way to test if you have a leak is to buy a blowout plug and connect an air compressor at 20 psi to your water inlet. Close all of your faucet's and let it sit there for a bit. If the psi's on the compressor go down, you have a leak. And that blowout plug is useful when winterizing your boat. But I agree with the inlet regulator being suspect.
Thanks for the helpful reply, I will give this a try.
At the risk of stating the obvious make sure the dockside water is turned off while away from boat. A small leak can turn into a big leak and in the case of city water pressure, quickly overwhelm a bilge pump.
FWIW I had similar symptoms that turned out to be the connection between regulator and FW system/plumbing. FW pump didn't generate enough pressure to cause it to leak but when on dockside water it sprayed pretty good. Now I use an automatic regulator that needs to be reset every 200 gallons. If I break a hose in the boat that is the limit to how much water can enter.
(11-02-2020, 09:52 PM)jclark003 Wrote: At the risk of stating the obvious make sure the dockside water is turned off while away from boat. A small leak can turn into a big leak and in the case of city water pressure, quickly overwhelm a bilge pump.
Thanks for the idea of the automatic regulator, could you tell me who makes it?
Go to Amazon and search for water timer. I would recommend a dial, not digital timer. they allow you to set how much water flows before shutting off. I set mine at 200 and reset it every weekend.
(11-09-2020, 09:57 PM)jclark003 Wrote: Go to Amazon and search for water timer. I would recommend a dial, not digital timer. they allow you to set how much water flows before shutting off. I set mine at 200 and reset it every weekend.
OK, will do. Thanks for the reply!
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 954 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,548 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,332 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,869 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,799 06-22-2025, 02:18 PM
