Tiara Open 2000 3100 no dock AC power, what would draw my house batts down from 12v to 9v?
Lost dockpower AC 90 days ago with storm surge. Batteries charge with alternators while running.
Only house batteries draw down over night, dramatically. Even when I switch the house batteries to off on panel Under the steps?
Thoughts ?
Have you load tested the batteries? How old are they? The only things that should be wired directly to the batteries are the bilge pumps. If your battery switches are off and your batteries are going from 12 to 9 volts over night I would start with checking the batteries. Also, if you have the same Balmar Alternators that I do just running the motors at idle at the dock will not charge your batteries. Need to be above 1000 RPM.
co detectors are probably hard wired also.
Sounds like you have a bad battery or two. One bad battery will pull the others down with it.
(11-13-2020, 06:54 AM)Sans Peur Wrote: Sounds like you have a bad battery or two. One bad battery will pull the others down with it.
I agree, that's why I never leave my battery selector switch in BOTH.
  2000 3500 Express Windshield Wiper Blade Replacements JMGCINCY2023 5 3,175 04-19-2026, 06:48 PM
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 715 02-18-2026, 09:15 PM
  [Tiara Open] 1989 3100 Open Wiper Arm Removal mmcintee1985@gmail.com 10 3,662 11-24-2025, 09:21 PM
  [Tiara Open] Need Source for Scuppers, 1995 3100 E-MAN 2 1,067 09-02-2025, 10:31 PM
Last Post: E-MAN
  2001 Tiara 3100 Open wipers IrvingVet 4 5,993 08-23-2025, 01:32 PM
Last Post: nylakeshome
