Refinishing Stairs
My stairs are beginning to ware. I think I am going to take the treads off and refinish over the winter. Has anyone done this? If so what did you use to refinish? Is there anything out there with some "Grip", the steps get pretty slippery when wet.
I used MinWax Spar Urethane [Helsman].....4 coats after cleaning them. On the last coat, I applied fine beach sand using a salt shaker to give them some grip......good luck!
When I did this Tiara recommended Repcolite low luster urathane with Awlgrip grip-text non skid. I think most urathane finishes will do the job
Thanks for the input.
Questions- Did you take it down to bare wood ? If so, what color stain was used if any?
I have 2900 open (99) and the 2 steps appear to have some color in them.
Tiara does not stain the wood. I have refinished my teak steps by sanding down to bare wood and refinishing with clear satin polyurethane and it matches the flooring quite well.
  Advice refinishing interior wood (teak veneers on bulkheads and cabinets) drywater 2 2,644 05-13-2025, 12:15 PM
  [Tiara Open] 1995 Tiara 43 Open water tank and door/stairs removal chrisrobinson99 3 3,282 03-13-2021, 09:59 AM
Last Post: chrisrobinson99
  Creaking stairs jclark003 8 8,397 01-16-2014, 11:57 AM
Last Post: Chris Burkard
