Good evening I’m new to the forum and this is my first post so please pardon if I don’t follow proper procedure. I wanted to share a troubling issue with my 2006 390 Convertible engine battery charger in hopes someone else has experience the same. The charger and system works great when powered by AC, but unfortunately the factory hardwire from the panel is not working. I will start by saying I know my way around boats as I have owned most my life. Here is the issue is short and what I have isolated:
The AC breaker is good. It has power in/out I checked at the panel.
The neutral (white wire) and ground (green wire) going into the charger are both good. I have isolated the issue to the black lead or power wire.
My thought is somewhere there is a GFI that has popped; however I have checked every outlet and GFI and reset and they are all good. I am unaware of an inline fuse on the AC side but think that could be an issue as well. I have checked other breakers (e.g. stove, hot water heater, cockpit freezer, etc) to make sure they are not sharing power and they all work. In fact, everything works great except the AC power to the engine charger. The house batteries are charged separately from the inverter. I even disconnected the lead line and fed another wire I knew was good and the charger came on me began to function. I don’t want to bypass the panel and retire but this is my only option at this point. Any direction or advise is welcome. Thank you in advance.
Larry
Larry
