Stain Color
So I had to take my stairs out to change some circuit breakers. I needed to get the old caulk off the stairs and the wall, so I used caulk remover. Well it also removed the stain on the wall. Does anyone know what color stain Tiara was using in 2002? I am guessing it is Early American or something similar.
Drop Tiara a note and they will give you both stain color and manufacture. I know on my '01 the teak was natural with a satin urathane finish. No stain.
I was able to match a swatch of original finish/stain (hidden underneath the galley bench) in my boat with Varathane dark walnut stain. Most people would think this would be too dark, but I did not let it soak in and the wood was sanded to 220 grit (which further prevents the wood from soaking in too much). You could also try Special Walnut, which is lighter, and build up the correct darkness in multiple coats.
Thanks Drywater. Tiara told me that that they do not use any stain. The dark tint is purely age.
  2000 3500 Express Gel Coat Color JMGCINCY2023 2 1,110 04-06-2025, 06:46 PM
  2000 4100 open salon headliner color Cor124 0 1,007 10-16-2023, 10:54 PM
Last Post: Cor124
  Seeking color advice bootss 1 2,120 03-14-2021, 02:00 PM
Last Post: Dakota773
  Gel Coat Color czarcone 2 8,742 06-15-2011, 05:09 AM
Last Post: czarcone
