Replacing aft cockpit seat covers - Sovran 3900
I am in the process of replacing the seating cover in the aft cockpit area (u shape lounge area) I have been able to remove all seating except one area - the cushion that is under the grab handle as you move from the cockpit into the helm station area. It seems the only access to remove the bolts for this handle and cushion is from the headliner in the cabin tv lounge. Has anyone tried this? Any advice welcome?
PR
I haven't owned the 39 in awhile, but if I remember correctly, there is an electrical panel on the side under the handle... Can you unscrew the electrical panel and get access behind it? I would suggest having the boat unplugged and batteries off just in case..
Max
(01-30-2021, 12:23 PM)Maxwell Wrote: I haven't owned the 39 in awhile, but if I remember correctly, there is an electrical panel on the side under the handle...  Can you unscrew the electrical panel and get access behind it?  I would suggest having the boat unplugged and batteries off just in case..
Max
Thanks Max, I know the location you are referring, however the handle that I am working on is actually the one aft, level with the first step into the helm station area.
Just completed the removal and installation of the aft cushions on our 39. The two 7/16”nuts are easily removed with access via under the aft stbd cushion going outboard. The most forward hand rail cushion was much more difficult. Best of luck!
  3500 Sovran trimtabs drprunner 0 92 11-14-2026, 03:44 PM
Last Post: drprunner
  [Tiara Open] Cockpit bolster removal Rick B 0 91 11-14-2026, 12:15 PM
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 570 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 735 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 520 07-28-2026, 06:28 AM
Last Post: Tiara45
