33 open battery parallel button
Looking for information on using the battery Parallel button on the dash.
If my starboard battery is dead... do I just push the button to use the other battery?
Do I hold the button in?
I never had this before... usually used a selector switch.
This boat is new to me.. and learning as I go..
The parallel switch on the dash operates a solenoid that connects the two starting batteries in parallel. So yes you hold the swich while you turn the key to the start position. Its a good idea to exercise it once in a while to ensure proper working order.
Great.. thank you very much
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 4,534 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 5,211 03-04-2026, 05:56 AM
Last Post: ken9090z
  [Tiara Open] 1996 33 open gauges Mydiamond 1 5,588 08-18-2025, 10:57 AM
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 5,222 08-14-2025, 08:05 PM
  XM radio connection to stereo - 43 open bnr@dur-a-flex.com 2 2,282 06-19-2023, 12:13 PM
Last Post: bnr@dur-a-flex.com
