Fresh Water Engine Flush
The current boat I have is a 31 Open. It has hose connections on each strainer that supplies water to the impellers to each engine. I routinely flush the engines but need to run the engines to do so. I saw somewhere that for engines that do not have lift mufflers that you can install a T fitting in the hose between the impeller pump and the engine input and flush the engine without running it because the 31 Tiara uses a wet exhaust system that water runs straight out the exhaust.
Anyone do this?
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 4 715 11-16-2026, 01:54 PM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 466 08-21-2026, 02:33 PM
Last Post: hmtrerice
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,841 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,955 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 583 02-15-2026, 05:34 AM
Last Post: maxcav
