2006 Volvo D6-370 air filter removal
Hi, I can easily remove the air filter cover from my engines but the filter seems to be stuck in the filter cover.  Manual states just pop out and replace.   Haven't been able to pop out, what's the trick?   I am ready for the laughs for not being able to figure this out.  Thanks
If I remember correctly, it should just come out. However I believe there is a rubber gasket around it that sometimes made it a little difficult to pull out.
(04-15-2021, 03:00 PM)Maxwell Wrote: If I remember correctly, it should just come out.  However I believe there is a rubber gasket around it that sometimes made it a little difficult to pull out.
Thank you, yes, it was just tougher to remove than expected, you were correct!!
  Oil Filter ? giff1 7 1,681 11-16-2026, 04:23 PM
  [Tiara Sovran] Low coolant temp Volvo Penta 600 Donaldjames 2 2,982 08-07-2023, 06:57 PM
Last Post: Donaldjames
  Performance Chip / Tuning Box for Volvo Penta D6-310 OffshoreTitan 0 1,494 05-19-2023, 12:39 PM
Last Post: OffshoreTitan
  [Tiara Sovran] Volvo primer bulb assembly Donaldjames 0 1,098 05-02-2023, 02:54 PM
  Zf 302v-ld trans prop shaft removal Docked Wages 3 2,971 02-19-2023, 12:27 PM
Last Post: Richard.Janek
