Oil Filter ?
I'm about to change the oil for the first time on my new to me 3500 exp.
I have Cummins 6CTA 8.3 and looking for the best brand of oil filters.
At this time the engines have NAPA 1748XD Xtended, which cost over $100 each.
What other oil filter brands that are good and where to buy them?
I have 6CTA 8.3 Cummins Diamonds (450hp) and use Fleetguard LF9009 oil filters. Assume your engines use the same.. M2C
(09-24-2023, 01:03 PM)giff1 Wrote: I'm about to change the oil for the first time on my new to me 3500 exp.
I know this i late but Cummins recommends Valvoline Premium Blue 15-40 oil, no synthetic blends.  But there are other HD oils that are equal it's just Cummins endorses the Valvoline.  I'd use Fleetguard filters LF3894 which is the upgraded filter.
I researched the appropriate filter for Cummins 6CTA marine 450 hp Diamonds and the LF9009 is what is recommended. THe LF3894 is recommended for Cummins 5.9 Ram Trucks
(11-15-2026, 08:56 AM)ReelMagic Wrote: I researched the appropriate filter for Cummins 6CTA marine 450 hp Diamonds and the LF9009 is what is recommended. THe LF3894 is recommended for Cummins 5.9 Ram Trucks
Oops i missed the 450 hp Diamond.
If I read your post correctly you stated you have 6CTA 8.3 engines which are the same as the Cummins 6CTA 8.3 Diamond 450 hp engines in my 2003 38 Open. The csorrect filter is a Fleetguard 9009LF (in the spec for these engines). If your engines are 5.9 Cummins then you are correct with the Fleetguard filters LF3894... From my reserrarch all 6CTA Cummins use Fleetguard 9009LF...  the 5.9 engines are known as the 6BT's and are only 5.9 L
Fleetguard LF9009 is the one I'd expect for the 6CTA 8.3 marine, but confirm it against your engine serial/CPL at a Cummins dealer before buying—that also gives you a reliable source. The NAPA number may cross, but don't rely on the pricey old label alone.
I agree with liambrown as it is critical to use the correct oil filter and oil... I use Rotella T 15W40 (recommended by Cummins) in addition to Valvoline Blue 15W40 as another great oil. Do no mix brands.
  Port oil filter change Afterburner 5 4,572 05-10-2021, 08:01 PM
Last Post: MC1600
  2006 Volvo D6-370 air filter removal gdynkowski 2 3,504 04-17-2021, 05:32 PM
Last Post: gdynkowski
  AIR FILTER honest mark 4 5,343 12-05-2019, 10:06 PM
