Tiara Open Waste cap replacement / Vacuflush
Hi
I have 2 problems maybe related
1.waste cap no longer seats in threads on through hull fitting tried numerous new caps Easy to replace both??
2. Vacuflush made by Domentic keeps cycling to gain air pressure even though new pump
(07-11-2021, 06:01 AM)if Knot now Wrote:
Hi
The pump cycling is to to a vacuum leak. The pump does not create pressure. It creates vacuum.  There is a leak somewhere in the system or a bad vacuum pressure switch.  A common problem is the duckbill valves, which are one way rubber valves on either side of the pump.
Agree w/Gmahnna, most likely a vacuum leak at the "duckbills". Believe you need 4 (2 each side of vacuum generator). I attached a parts list for my system but most likely they use the same duck bills (part #14). M2C
.pdf   Vaccum Generator VG2 diagram_Parts.pdf (Size: 1.09 MB / Downloads: 9)
Does you toilet hold water in the bowl? I recently had to replace the bowl.seal as it would leak the water into the vacuum system and once dry they don't seal and the pump would cycle on all the time.
  38 open ice maker replacement williamwalter 7 6,074 08-22-2023, 11:46 AM
Last Post: Flatliner
  New owner of 3800 Open, vacuflush question ajcjr 13 10,313 07-13-2021, 02:19 PM
Last Post: neto
  [Tiara Open] Helm seat replacement with Captains chair ReelMagic 0 2,176 06-22-2021, 03:48 PM
  Fuel tank replacement dbruce222@gmail.com 2 3,161 05-03-2021, 07:32 AM
Last Post: MC1600
  2004 52 Sovran Salon upper salon headliner replacement Knot On Call 3 4,514 07-20-2020, 12:08 PM
Last Post: Knot On Call
